WR450 rotor did I screw it up?
3 replies to this topic
  • glenm
Posted March 19, 2003 - 04:13 PM
Ok so I get it home tonight and can't resist the poking, rubbing, and fondling of it. After the foreplay I just had to check the rotor torque. Anyway I had mistakenly turned the entire nut and rotor about ¼ - 1/2 turn the wrong way. I didn't affect any of the valve or ignition timing did I? Couldn't start it to find out because I didn't want to disturb my tenant upstairs. I apologize for my mechanical ignorance.
  • Indy_WR450
Posted March 19, 2003 - 08:40 PM
Retorque to 50 ft lbs and you are OK
  • BEAN329
Posted March 20, 2003 - 01:56 PM
No problem, Sorry to hear about your neighbors.
  • Dutch
Posted March 20, 2003 - 02:12 PM
If you turned the entire rotor assembly then you don't need to retorque the rotor nut, (not that it wouldn't hurt to do it anyway), you didn't loosen anything if both the rotor and nut turned.
