How often do you check the oil pressure bolt?
8 replies to this topic
  • davcon
Posted June 24, 2009 - 05:53 AM
I confess, I dont loosen the bolt to check for oil pressure. I did it after the bikes first oil change but the dang thing leaked while on the trail. When I got back I had to slightly overtighten it to get it to seal. How often do you check? Every oil change?
  • ca_101
Posted June 24, 2009 - 08:52 AM
I check mine on my 426 every change, just as recommended. It shouldn't leak if torqued to the correct spec. 18Nm (13ft-lb.) on mine.
  • Wiz636
Posted June 24, 2009 - 10:47 AM
Never :worthy:
  • 642MX
Posted June 24, 2009 - 01:24 PM
I checked mine once.... after I put a new crank, mains, and pump/rotor in it. I was a little paranoid I guess. :worthy:
  • ThumperKid250F
Posted June 24, 2009 - 01:52 PM
to be honest i never checked it, and to be even more honest i dident even no we had a oil pressure bolt
  • TIG88
Posted June 24, 2009 - 02:13 PM
Mine gets checked every new top end :worthy:
So this means about once every 6 years :lol:
  • Hughes
Posted June 26, 2009 - 04:23 AM
It's recommended to check it at every oil change.
  • BlackT5
Posted June 26, 2009 - 04:40 AM
Everytime I change the oil I check the oil pressure. Seems like a no brainer.
Posted June 26, 2009 - 06:53 AM
I seldom ever check it. Unless you are using a Ready Racing filter cover, or some other cover besides the original that does not have the tab extension that prevents the inverted installation of the filter, there isn't anything you can do during an oil change that can keep it from circulating oil, short of forgetting to refill the bike.
I usually just give the starter a flip while the oil filter's out and watch for a discharge from the main feed passage in the filter well. It would actually make more sense to check oil pressure each time you ride, but since most people don't change their oil each ride, that doesn't happen, and since the threads in the check bolt are not steel lined, they would not survive this in the long term.
What I'd like to see is a fitting tapped into the oil system with a visual tell tale pin that would extend (or retract) when oil pressure was present, so it could be checked any time. That, or a physical, visual check of circulation as was traditional years ago on virtually everything with a dry sump system.
  • On January 15, 2017
  • Hot  30 replies
  • Hot  28 replies
  • Hot  38 replies
