reliability...
10 replies to this topic
  • dangerider1982
Posted June 23, 2009 - 09:02 PM
So I am coming off of a 2000 yz426 with original top end and insane amounts of abuse with VERY little maintenance. My question is are the newer generation engines; 2006 yz450 and up just as reliable or close to it? I am thinking about upgrading, but have not heard as many great things about the reliability of the newer bikes, let me know of your guys' experiences
Thanks,
Marshall :worthy:
  • husqy360
Posted June 23, 2009 - 11:51 PM
150 hours with no problem.
  • 642MX
Posted June 24, 2009 - 01:32 PM
Thanks,
Marshall :worthy:
Good question. From what I see on the forums, I honestly don't think the newer 450's hold up as well as the older 4XX's. Of course the YZF's have been so bullet-proof in the early years that I think some folks have become a little lethargic about proper maintenance when they've upgraded to the newer 450's.
  • TIG88
Posted June 24, 2009 - 02:09 PM
X2
I seem to have seen the same thing. I think Gray said his 03 YZ had like 400 hours on the valves and original piston (new rings)??
My 03 has the original shims from the factory on all valves. They are just starting to get a little tight. I will adjust them when I see a little more movement. It also had the original top end and timing chain until this spring. The piston measured in spec and the chain didnt have kinks in it. It hasn't sat either.
I do have a high speed headshake that I dont have time to mess with and leaky fork seals (which probably caused the headshake).
  • desert-rat660
Posted June 24, 2009 - 06:04 PM
my bike has been pretty reliable its an 06
  • spark250
Posted June 25, 2009 - 10:44 AM
I have an 06 as well. The motor has been relatively bulletproof, but I've had some trans issues. I think it was the first year for the 5 speed?
  • Ga426owner
Posted June 25, 2009 - 10:53 AM
my 03 and 06 have held up just like my 400s and 426s. These motors are bulletproof if you maintain correctly.
You will prefer the feel/ergos of a 06 to any 426 as it will feel 35lbs lighter, and 6inches slimmer
  • husqy360
Posted June 25, 2009 - 11:12 PM
yes 05 was 4 speed.
i somtimes have problem from 1st to 2nd gear, but after seeying 2008 kawi tranny break within 20 hours im happy with mine.
guess ill try adjusting the shifter alittle more.
  • hillclimbguy
Posted June 26, 2009 - 06:19 AM
I've had real good luck with the 06 450.
  • RJacks
Posted June 26, 2009 - 06:20 PM
Reliability on the YZF's are second to none as long as you don't neglect them. I have 100 hours on my 2007 and I am hard on bikes. The bike hasn't required a valve adjustment or anything else but a clutch since I've had it. I have taken two 3 month breaks in the last year, but the hour meter doesn't lie. Oil change every ride, and also air filter, that keeps the motor happy.
  • Kent Rathgeber
Posted June 27, 2009 - 09:11 AM
Yeah, what RJacks said!!!:worthy:
He might be a little extreme on the oil changes, I change mine every 3 rides. It still comes out of the engine pretty clean.
I am paranoid about my air filter maintenance, though. As soon as I see dirt on the filter, it gets changed.
  • Hot  30 replies
  • Hot  113 replies
  • 10 replies
