XR250R Dual Sport Conversion
3 replies to this topic
  • n0f3ai2
Posted 23 June 2009 - 05:41 PM
Right now I'm unsure on how/what I need to make my XR250R street legal (1986)....
So far, I have:
Dual Element Light Socket/Wirehttp://www.xrsonly.c...emart&Itemid=89
Brake light bulb
Hydraulic Brake Light Switch (I plan on mounting the brake light switch on the front brake since the rear brake is not hydraulic and I can't find a place to mount one for the back brake)
Should that be all I need to have a dim brake light that brightens with brake pressure, or will I need a resistor?
Also plan on buying a horn and dual sport tires if I can find some to mount on the stock wheels. I believe all I need for a dual sport here in New Hampshire is D.O.T. Tires, a horn, and a brake light...
Thanks
  • Tomttt
Posted 05 July 2009 - 04:38 PM
I have a 93 that I installed a baja designs kit on. It came with a mech. brake light switch, but I have changed to a hyd. switch and it is much better. Do you have disc. rear brakes?:ride:
  • n0f3ai2
Posted 06 July 2009 - 07:45 AM
Thanks for the reply. Nope, my rear brake is a drum. I believe that they went to a disc brake the model year after mine :foul:
  • inthedirtagain
Posted 06 July 2009 - 12:29 PM
I posted several threads to my conversion. Your bike will be very similar to mine. I've since switched out to a UFO dual-headlight and 12v conversion.....much better!
