97 CR250 swing arm
9 replies to this topic
  • mark96yz250
Posted June 23, 2009 - 12:01 PM
Does anyone know what years will interchange swing arms? I just bought mine and while stripping it down to put swing arm bushings/bearings in I found that the chain has rubbed through the arm. Also, would someone please list a source for interchange info. Thanks, Mark.
  • duramax1031
Posted June 23, 2009 - 02:27 PM
I had the same exact problem.I bought a used one off ebay and it came with good bearings for 80 bucks or so.I believe '97 through '99 will work....
  • mark96yz250
Posted June 23, 2009 - 05:17 PM
I already have the bushing/bearing kit and it says it fits 92-01, but I don't want to assume that those years will interchange. Thank God I still have the YZ to ride!
  • mlglemon
Posted June 23, 2009 - 09:33 PM
Yeah the '97-'99 will definitely work, since they are the same...so I would find one on Ebay.
  • duramax1031
Posted June 24, 2009 - 09:02 AM
:worthy:
  • rider58
Posted June 27, 2009 - 03:13 PM
find someone who welds alum. weld it up and grind and sand it smooth. While your sanding ya mite what to sand the whole thing and polish it if your into that look. I welded my buddys and he didn't like the look I left after I grinded the built up welds that would have bin hidden under the chain guide, so he sanded and polished it , I admitt it dose look cool.
  • mark96yz250
Posted June 28, 2009 - 04:59 AM
I think this is the route I'm gonna take. My buddy has a good welder for aluminum, so I think I will run it up to his place and weld it up.
  • MIllerman
Posted June 28, 2009 - 08:01 AM
The 97 has different linkage than the 98 or 99, they don't fit. They use a different dog bone setup than the 97.
  • mlglemon
Posted June 28, 2009 - 08:45 PM
Oh, you know what, I completely forgot that. My bad....but does that affect the mounting point for the linkage to the swingarm? I'm thinking not...:worthy:
  • MIllerman
Posted June 30, 2009 - 05:14 AM
I think it was only different where the linkage bolts to the frame. I think the swingarm part of it is still the same. From what I remember, you need a 98 or 99 frame to fit the 98 to 99 linkage. The 97 has it's own design. the triangle part should be the same but the dog bone is a one piece part like the newer 450's on the 98 and 99.
I have a 97 I rebuilt and I needed a swingarm also. I noticed the differences when shopping around.
2006 CR125 Startup Help by Will I Am
Dirt Bike   Make / Model Specific   Honda   Honda 2-Stroke
  • 13 replies
My new near-mint 2002 cr250r by md30
  • Hot  51 replies
What did you do with your CR today? by thetinkerer
  • Hot  69 replies
what bike? KTM,RM,YZ,KX,or CR 125 by Numsa Hul
  • 8 replies
optimum lowend torque sprocket size cr80r by ericinkmonster
  • 17 replies
