Can '09 pass 96 bd at 20" w/o peeshooter?
4 replies to this topic
  • rkwfxd1
Posted June 23, 2009 - 07:25 AM
Can the 08/09 WR450Fs pass the 96DB at 20" sound test with the "peeshooter" removed from the stock exhaust?
I did a lot of searching and I know Yamaha makes a couple of quiet tips that will do this but was wondering if anyone had done the free mods and acutally had their exhause tested for DB without the peeshooter.
Thanks
  • SJMC_DON
Posted June 23, 2009 - 08:00 AM
Thanks
If you remove just the peashooter... yes, it will pass without a problem, it's probably still below 90db at that point.
You can remove the tailpipe altogether but retain the S/A screen and it will definitely be louder and i think it will fail a standardized test.
I had the GYTR enlarged endcap for a while and it would blow 96db most of the time.
  • Ironhorse
Posted June 23, 2009 - 03:29 PM
I've had my 08 tested twice with the pea shooter removed. First time it read 96db. Put about 40 miles on the bike and tested it again this Sunday at a different event and it tested 98db. They kind of frowned at me. The bike only has about 100 miles on it so it doesn't need to re-packed. I drilled out the little insert that's in the pea shooter and I'lll put it back in and see how it runs.
  • JSanfilippo
Posted June 23, 2009 - 05:54 PM
The pea shooter is that black metal thing in the stock external baffle. If you were to drill it out you'd be around 88-90 db (mine tested 88 db)
If you were to take the baffle completely out it would be loud. IIRC its about as loud as a stock '07 YZ exhaust...which is about 97-99 db.
  • rkwfxd1
Posted June 23, 2009 - 06:21 PM
OK so now it sounds like in order to pass the 96db at 20" test I will have to leave the peeshooter in but drill it out for a bit of performance increase.
What size drill bit?
