Oil question
4 replies to this topic
  • thmlrmg
Posted June 22, 2009 - 07:41 AM
Ok guys, I live in tennessee where the temp is about 95 and the humidity is about 95%. I was wondering what oil I should run. I would like to run something that I can get at a local auto parts store instead of ordering it. I currently run 10w-30 and someone at the track said that probably wasn't good enough. Thanks for the help.
Posted June 22, 2009 - 08:16 AM
Look in your manual.
(no excuses: http://www.yamaha-mo...ice/manuals.jsp
http://www.yamahaown...ook.com.au/?r=0 )
In section 2 the oil grade requirements for temp range is laid out. 30 wt oils (or *w-30 multi-grades) are only recommended up to 70 ℉ outside air temps. You should be running an *w-40 at least. I generally start running *w-50's when it gets that hot or hotter.
If you order Amsoil MCF or MCV by the case, you'll have it on hand, save money over other premium M/C oils, and never have to go get it.
Otherwise:
http://www.thumperta...432#post2685432
  • CRFRider1987
Posted June 22, 2009 - 08:19 AM
i live in middle tn and i run 10w30 in the cooler months and 10w40 in the summer
  • 642MX
Posted June 22, 2009 - 09:08 AM
It gets that hot here too. Its suppose to be 97 degrees today. :worthy:
I've posted it a million times, but Shell Rotella 15W40 works perfect for me in this hot & humid climate. The temps range from 0 degrees to 100 degrees and I use it year round.
  • yz480doinwork
Posted June 22, 2009 - 06:35 PM
has anyone ever put yamalube 2-R in the 450. i ruined a cam chain in my bike. two things could of happined. sand could of ruined the chain (i dont see how it didnt ruin the rest of the engine) or i accidently put 2 stroke oil in my bike. or was maybe it was just a bad chain to start with. kinda off topic but this is a good place to ask. could 2-R caus a cam chain to lock up?
  • 10 replies
  • Hot  47 replies
Motocross
  • Hot  491 replies
  • 9 replies
