Just finished adding lights/horn to my 2009 KLX140L. Not that simple, but can be done by someone with electrical experience. You can get a whole kit, but those are expensive and often contain turn signals - which I did not want. So I obtained a KLX140L wiring schematic, a Baja Designs headlight, Acerbis tail light, aftermarket light switch, brake light switch, horn, wire, PVC sleeving, bullet connectors. Looks and works very nicely. Brake light and horn work with main bike switch off. Other lights require the bike to be turned on. If anyone is interested, I could post more info.
KLX140L - Adding lights for street legal
Started by netra, Jun 21 2009 02:49 PM
6 replies to this topic
Posted 21 June 2009 - 02:49 PM
Posted 25 June 2009 - 03:54 AM
I used the whole Baja kit on my wifes bike. Switched it to a key ignition and added a cheap speedo at the same time. I ended up making quite a few changes to get everything working properly.
Post some pic's.
Gazoo
Post some pic's.
Gazoo
Posted 26 January 2012 - 06:35 PM
i just did the baja designs enduro kit on my 140, i works great but what are the 2 little extra wires by the headlight plug for, on the baja wiring??
Posted 09 February 2012 - 03:02 PM
Does the 140L have enough stator to effectively run lights?
Was looking at a Honda CRF 150 for a Baja conversion for my wife... but read that it will need a stator change to do lights?
Vinduroman
Vinduroman
Posted 09 February 2012 - 03:44 PM
Vinduroman
Vinduroman
http://www.thumperta..._1#entry6347132
