Changing Oil
4 replies to this topic
  • Dee Perry
Posted June 20, 2009 - 11:51 AM
Just changing the oil on my 01 WR426. I only drained about a cup full from the engine and the rest from the frame. Is this normal? I would have expected more from the engine drain. Last time I changed the oil I did not pay attention to how much oil came from where and I changed the filter and the screen. Just want to make sure I did not mess something up. Thank you in advance for your help.
Dee
  • Lcpl0331
Posted June 20, 2009 - 04:47 PM
yup normal.
  • mightymart
Posted June 22, 2009 - 10:38 AM
Unsure if theres a hard & fast rule ? but dont you drain from the frame first then the sump ? I have an 07 so no oil in the frame
Posted June 23, 2009 - 09:51 AM
Your bike has a Dry Sump oiling system. The oil is used in the engine, but it isn't kept there:
http://www.thumperta...903#post5221903
Yours is also a dry sump, same as the '06 and earlier. The difference is that the "tank", or feed oil reservoir, is integrated into the engine cases. It's a separate volume, nonetheless.
I drain the feed reservoir first, then the filter, then the sump.
  • Dee Perry
Posted June 24, 2009 - 02:11 PM
Thank you GR. sure do appreciate your time and help.
