wr450 e start help needed
11 replies to this topic
  • trc52001@cs.com
Posted March 18, 2003 - 02:30 PM
trying to e start my wr is driving me crazy. i have gone to a 165 main, 48 pilot, 72 starter jet, baffle removed, airbox snorkle removed, grey wire cut. occasionally the bike will start with the electric start when cold, but i cannot get it to start when warm. it is embarrasing riding with my buddies and my brand new bike won't start. it starts fine with the kicker and runs like a champ, so i feel sure it is not the woodruff key. if anyone has any suggestions i would truly appreciate it.
thanks
jim
  • Jonesy920
Posted March 18, 2003 - 08:07 PM
Not to question your intelligence but are you pulling in the hotstart trigger ? With it pulled mine starts awesome with the electric starter, once it's warmed up :D :)
  • BEAN329
Posted March 18, 2003 - 08:24 PM
Same here, hot start lever a must when hot.
  • ddialogue
Posted March 19, 2003 - 04:53 AM
If my bike has been shut off for more than a few minutes after riding, I have to crack the throttle 1/8 (and always use the hot start) and it fires right up.
  • trc52001@cs.com
Posted March 19, 2003 - 04:08 PM
thanks for the replys, but yes i am using the hotstart. i've tried not giving any throttle at all, blipping the throttle before hitting the button, and opening throttle part of the way while hitting the button. it is turning the starter over fine, but it just won't fire the motor. i pull out kick starter and it usually only takes one kick. any other ideas or suggestions(jetting maybe) would be appreciated.
thanks
jim
  • Jonesy920
Posted March 19, 2003 - 06:42 PM
Utvols had the same problem and the key had sheared but just enough to mess up the timing...Hate to say it but maybe you should check it out.
  • trc52001@cs.com
Posted March 20, 2003 - 02:09 AM
i am going to order a flywheel puller and check the key. i will probably post again when my puller get here and hopefully someone can take me step by step through the procedure.
thanks
jim
  • Moon
Posted March 20, 2003 - 11:01 AM
Ocassionally, mine has not started when I felt it was warm and was using the hot start lever. I pulled the choke and it started right up. I don't touch the throttle as the manual says not to.
  • wr250rr
Posted March 20, 2003 - 01:50 PM
Ditto on the choke. If mine has been off for 5 min. or more, I give ole Sally full choke and no hot start.
  • tootall
Posted March 20, 2003 - 05:28 PM
Just a thought but if it starts every time with the kick starter,try jumping it with a good battery to prove it's not a weak battery.
Darrel
  • starttman
Posted March 20, 2003 - 06:21 PM
i'm gonna go against the grain here...I will get blasted...but ....try snapping the throttle one quick time to prime the combustion chamber.do that with the hot start open...then try to start it.let me know what happens.
chris
  • Lon13
Posted March 23, 2003 - 06:22 PM
Put 'er on a battery charger, it might help. Mine would not start with the button cold when I got it. I put it on a tender because the battery was low. It starts fine now.
