02 426 problems
2 replies to this topic
  • twoYZ426Fs
Posted June 19, 2009 - 10:05 AM
I just bought an 2002 426 from a guy for $800. It was a great deal in my opinion. When he started it up, it was spitting and sputtering/backfiring, and about 15 seconds after it was started, the exhaust pipe coming from the jug was red hot. It wasnt just discolored either. I was wondering if anyone had any suggestions on where I should start with fixing the problems. Heck, does anyone know what the problem might be?
Thanks in Advance,
Alex
Posted June 19, 2009 - 10:12 AM
Start with the carb. Look for varnish deposits in the jets.
  • RCJIM
Posted June 19, 2009 - 01:34 PM
do the basics first, it will save you money
Change gas out use 92 octane
Change oil and filter,check/ clean screen in neck tube
Change or clean spark plug/check spark plug wire. replace if needed
clean carb, jets, bowls, linkage etc..
i trusted starting rules for a 02 yz426 as follows
1. pull choke out
2. twist throttle full open and let snap shut(this is the last time you should touch the throttle)
3. pull kick start out cycle kicker til it stops, bump compression lever just alittle til the kick moves slightly down, let the kicker back to the top and kick like hell
4. i have never had my bike not start up within 3 kicks
good luck hope there isnt any problems
Motocross
  • Hot  491 replies
  • 10 replies
  • Hot  113 replies
