aftermarket rev limiter for dr650
7 replies to this topic
  • rieds
Posted 18 June 2009 - 08:08 AM
i found a dyna rev limiter listed as available for a dr650 model drl-300cdi but a guy i talked to at dyna said there isn't one available for the dr650. is it maybe made for a drz400 and will plug up to the dr650 or are these people off there rocker?
  • mxrob
Posted 18 June 2009 - 08:58 AM
The power drops off so fast after 6K rpm on the big DR that a rev limiter set higher than the stock 7500/7600 is totally pointless. :lol: Shift it sooner to go faster. :worthy:
  • casmiths
Posted 09 July 2012 - 07:57 PM
View Postmxrob, on 18 June 2009 - 08:58 AM, said:
The power drops off so fast after 6K rpm on the big DR that a rev limiter set higher than the stock 7500/7600 is totally pointless. :D Shift it sooner to go faster. :)
Hey Rob, when we change the OEM carb to a FCR39, ?what we do with the rev limiter?
  • NordieBoy
Posted 10 July 2012 - 02:31 AM
Nothing.
At the limiter you've got the same HP as at about 4,500rpm.
At 6,500rpm you've got the same torque as at 3,000rpm.
For max performance, everything points to shifting at about 6,500-7,000rpm.
For trail riding it's more like 5,000-5,500rpm and it'll drop to 4,000-4,500rpm, right in the meat of the torque.
  • casmiths
Posted 10 July 2012 - 08:36 AM
View PostNordieBoy, on 10 July 2012 - 02:31 AM, said:
Nothing. At the limiter you've got the same HP as at about 4,500rpm. At 6,500rpm you've got the same torque as at 3,000rpm. For max performance, everything points to shifting at about 6,500-7,000rpm. For trail riding it's more like 5,000-5,500rpm and it'll drop to 4,000-4,500rpm, right in the meat of the torque.
Rob, sorry for my lack of knowledge, the question yesterday about the REV limiter and the carburetor was because I thought that what was in the carb ( the litle switch) was the mentioned rev limiter, but I think that is the throtle position switch.My question is: where is the rev limiter? I look at the diagram and could not locate.
  • NordieBoy
Posted 10 July 2012 - 12:34 PM
The US spec bikes don't even have that switch.
The rev limiter is in the CDI.
NotMXRob
  • casmiths
Posted 10 July 2012 - 02:53 PM
NotMXRob
thanks NordieBoy,and do you know what the TPS do?
  • NordieBoy
Posted 13 July 2012 - 07:25 PM
Nothing that the Dyno can detect.
