Titanium: lightweight AND strong? Whatever...
9 replies to this topic
  • ddialogue
Posted March 18, 2003 - 05:09 AM
My brother-in-law laid down his WR450 on the right side while going about 30mph. No damage done to the rider or bike...so he thought. After looking at the bike he realized the header had been severely bent. Here are some shots of it:
Looks like it's going to be an expensive replacement. My question is this: So...are there any aftermarket headers that are affordable and will fit up with the stock WR muffler? I'm sure a replacement OEM header is going to start at somewhere around $300.
  • starttman
Posted March 18, 2003 - 05:37 AM
go to EBAY
YZ WR 400 Stock Yamaha Head pipe 426 YZ400F
Item # 2407433637
  • rockieman
Posted March 18, 2003 - 06:14 AM
Before you go spend a fortune replacing your pipe.....I would give Bret a shot a Pacific Crest pipe repair. http://www.piperepair.com He typically charges $40 bucks.
Good luck! :)
  • cnacc
Posted March 18, 2003 - 06:35 AM
Check out Motoman393 page he has directions to fix dinged up pipes, A friend of mine did it and it works amazingly!!!
only costs about 10 bucks, plus beer.
  • jwriott
Posted March 18, 2003 - 09:01 AM
Titanium has slightly less yield strength than steel but is about 1/2 as stiff. It is also 1/2 the mass of steel.
If you have 2 tubes one of Steel and the other titanium, with the same diameter and wall thickness, the titanium tube will not be as strong. The titanium tube will be 1/2 the weight.
  • thealexdexter
Posted March 18, 2003 - 04:08 PM
thunder alley sells them...$100 I think
  • thelimey1
Posted March 19, 2003 - 12:06 AM
beware trying to fix a titanium headpipe like you would a steel one.
motomans site has some great stuff, but the same rules do not apply to titanium. steel reaches a yield point when heated, so that it gives. the internal pressure you apply with compressed air pushes out the dents. titanium does not yield when heated, you will ruin the item before it decides to yield. for what its worth.
  • ddialogue
Posted March 19, 2003 - 03:45 AM
THANKS for all the information guys! We're going to bag trying to fix it and probably get a replacement. I found a used 426 header locally for cheap and he's going to try and fit it the next couple of days. I'll let you know if it works or not.
  • Jonesy920
Posted March 19, 2003 - 01:01 PM
I Second the Pacific coast pipe rpair. Brette can fix anything and he truley has a one day turn around . I have used him and I was more than pleased with his work. He also will give you your money back if he can't fix it to your satisfaction.It's worth the $40 to at least tryit.
  • The_Blue_One
Posted March 19, 2003 - 01:16 PM
If your not gonna use the stocker can i have it?I could come up with a few bucks if needed.
