Do the OEM steering bearings include the race?
4 replies to this topic
  • nickeenoo
Posted June 17, 2009 - 08:31 AM
I am replacing the upper and lower steering stem bearings on my 07 450 and am wondering if these are the part numbers I need and if the OEM part numbers include the races.
93332-00078-00 Upper bearing
4EW-23416-00-00 Upper cover
93332-00081-00 Lower bearing
Is this all I need?
Thanks,
Nate
  • Ga426owner
Posted June 17, 2009 - 08:33 AM
They include the races
Posted June 17, 2009 - 08:43 AM
The 23416 upper cover is the seal above the bearing. You may or may not need to replace that. Otherwise, yes, you have everything you need listed except the grease. Use a high grade EP2 Marine Grease, preferably one that contains Moly.
  • nickeenoo
Posted June 17, 2009 - 08:51 AM
Thanks, I do need the upper cover as it had a small tear in it. Also, when getting the lower bearing pressed on the stem (I'll have the local shop do it) I'm assuming it is best to have it packed with grease before they press it on?
Nate
Posted June 17, 2009 - 09:26 AM
It's easier to do it that way because you can use a bearing packer while the bearing is free. Otherwise, it doesn't matter much.
