Fitting Reserve Fuel Tap To 08 YZ450
12 replies to this topic
  • roylo
Posted June 16, 2009 - 03:46 AM
What is involved or is it possible to fit a WR or similar fuel tap with reserve to my 08 YZ450? What is the easiest way to go about it and will it fit straight on?
Thanks for any replies..
  • WB450
Posted June 16, 2009 - 06:57 AM
I think you can just order a WR petcock that will bolt right up. I know I could do this with my 07.
  • Wiz636
Posted June 16, 2009 - 08:05 AM
Yep, just throw on a fuel petcock from a WR.
  • roylo
Posted June 16, 2009 - 08:26 AM
Anyone know which WR year models will fit or which is the better one to get?
  • mitchicle
Posted June 16, 2009 - 08:54 AM
I would say get the one for the 08 WR
  • WB450
Posted June 16, 2009 - 09:06 AM
Check this old thread, the end addresses the petcock issue. Like I said I had the choice of WR or YZ when I bought mine. I'm sure the TT OEM store could help you out.
http://www.thumperta...s tanks petcock
Posted June 16, 2009 - 09:58 AM
'07 or later, so that the form factor is the same as yours.
  • roylo
Posted June 16, 2009 - 04:48 PM
Cool. Thanks everyone for replying :thumbsup:
  • B_DRZ
Posted June 16, 2009 - 07:04 PM
Whats the benefit of doing this mod?
  • Todddob
Posted June 16, 2009 - 07:22 PM
When you run out of gas, you switch it to reserve and have enough to limp home. Say, how much would the WR petcock leave you in reserve?
  • roylo
Posted June 17, 2009 - 12:46 AM
A reserve fuel tap is basically there just to let you know when your running low on fuel. The bike will run out of fuel or start to when there is a litre or so of fuel left in the tank, then you turn the tap and use whats left in the tank.
I too would like to know how much fuel a 08 WR fuel tap would leave in the tank when set to reserve? Anyone know?
  • B_DRZ
Posted June 17, 2009 - 06:07 PM
I always thought that bikes that had reserves on them had some special section in the tank. Thanks for the info.
  • mitchicle
Posted June 18, 2009 - 01:06 PM
No the main pick up tube is longer than that of a non reserve fuel petcock. So instead of having one tube, the reserve fuel petcock has one long tube and one short one.
  • Hot  50 replies
  • 0 replies
  • Hot  30 replies
  • Hot  47 replies
