Oil Change.
2 replies to this topic
  • DennisT450
Posted March 17, 2003 - 03:21 PM
Did my first oil change. Did'nt know oil would shoot out the frame like that.So how much does the 450 hold(with new filter)? Also my manuel shows a screen needs to be cleaned. How often should that be cleaned and whats the easiest way to get it out? It sure ain't like my 2-stroke.
  • Jonesy920
Posted March 17, 2003 - 07:26 PM
take out the bottom drain plugs first and it won't shoot all over your front tire, just the fender :) I bought a scott's filter and clean it every time I change the oil, the other "screen" is in the lines behind the skid plate, I think the left one, I think its 1.1 L with filter and 1.0 without the manual has the info on that.
  • Motorod
Posted March 18, 2003 - 02:12 AM
How often do you change the oil? I changed mine after first tank, found nothing in the filter, was expecting some chips. After two tanks, changed just oil, and it look pretty good also.
