Another wr450 bites the dust.
6 replies to this topic
  • Will450
Posted March 17, 2003 - 06:22 AM
At least it happened in my driveway. 16 miles. ruined weekend plans. etc.
  • endurodog
Posted March 17, 2003 - 06:32 AM
Had you retorqed the flywheel nut? lapped in the rotor?
  • Will450
Posted March 17, 2003 - 06:48 AM
No, nothing. It's going to dealer tommorrow.
  • WR250fla
Posted March 17, 2003 - 06:59 AM
Will450,I read your post about you retorquing you rotor nut on the 15th then it wouldn't run...Whats going on?
  • Will450
Posted March 17, 2003 - 12:43 PM
wr250fla,
Actally I did not re-tourqe it I just got a socket on it and tightened it back up. The timing must be off cause it will not fire up. Just pops a little.
I'm just guessing that the woodruff key sheared.
  • Superbike
Posted March 17, 2003 - 01:58 PM
Mine did the same. Quit running only popped. It was only a plug. I am not saying it is not a key, I thought mine was. With the stock jetting I had the choke on for so long just to get it to run, I fouled it. ---Mike
  • Will450
Posted March 17, 2003 - 02:48 PM
Mine just started and when I let it die and tried to hit the starter button it just freewheeled. I opened the access hole and noticed the nut had backed off. I tightend it up and the starter would engage and turn the engine over but wouldn't fire. I guess the timing was affected.
