JDjetting kit received - no info on what settings for a free flow exhaust?
8 replies to this topic
  • MTS II
Posted June 11, 2009 - 06:23 PM
I was under the impression the kit would have a setting for stock exhaust setup and one for a free flow. I have a Yosh pipe/header setup - pipe has spark arrestor - should i just use the only setting that JD included?
Also - are most YZ426 owners running the thick or thin o-ring? My bike is an '02.
Thanks
  • biwwy2000
Posted June 11, 2009 - 07:38 PM
just call jd
they are great and will help you out with any question.
they have seen it all.
using the o ring results in less delay between throttle movement and ap activation.
the thicker o ring has a qricker response than the thinner one.
some riders don't even use and o ring and just use bailing wire for instant response.
i use the thicker o ring for quick response but with some give.
biwwy
  • MTS II
Posted June 11, 2009 - 08:41 PM
Went ahead and did the install with the 170, blue needle in the 4 position, thicker o-ring.
Turns out this bike had an o-ring on it at somepoint - I found it when installing the new one. The old one was split in half. Testing this out on Sat.
Posted June 11, 2009 - 09:40 PM
What makes you think that the stock 426 pipe is not a free flowing exhaust? Or that the Yosh is that different? There is likely to be very little difference, if any, in the ideal jetting for either pipe.
  • MTS II
Posted June 12, 2009 - 07:10 AM
Was told that information by a few people. I went with the stock JD setup after reading a couple more threads here that there is not much difference.
Posted June 12, 2009 - 07:56 AM
Look this one over, too.
http://www.thumperta...699#post2881699
  • Diode663
Posted June 12, 2009 - 09:40 AM
Correct me if Im wrong, but isnt the blue needle for cold weather?
  • DND
Posted June 12, 2009 - 03:10 PM
You are correct. JD's instructions say to use the Blue needle for conditions below 50F.
  • 642MX
Posted June 12, 2009 - 03:31 PM
I've had the best luck with the red needle... I'd also throw the o-ring in the trash, they break in a short period of time. I wired mine. :thumbsup:
  • Hot  113 replies
  • 5 replies
  • Hot  47 replies
  • Hot  38 replies
