WR400/426 - YZ400 silencer interchangability?
2 replies to this topic
  • PumpkinHumper
Posted June 09, 2009 - 07:01 AM
I have a buddy with a 99 YZ400 that is in need of a quiet(er) spark arrested silencer for his bike as the stock MX silencer is freeking loud and illegal in Michigans woods. He dont have the $ for a new silencer and even the PMB insert for his stock can is around $200 with the quiet insert. hell he dont even have $ for piston/rings and chain and sprockets that he desperately needs... :thumbsup:
But then I got to thinking will a WR400/426 stock silencer work on his bike? There has got to be a few of those big black ugly oil cans out there cheep as they were pretty horible stock. But with the insert PMB sells for the stock WR can for $40 its gotta work better. That has got to be a cheeper solution for him.
I know when the YZ/WR's 1st came out a lot of the parts were inerchangable. Would the WR silencer work on his bike?
Thanks.
  • yamaha racing 230
Posted June 09, 2009 - 10:49 AM
it will work but the mount at the mid pipe will need alittle mod to bolt up , why doesnt he moddify the stock yz endcap and reduce the diameter of the tip that will reduce the DBs tremendesly and wont cost much money
  • SXP
Posted June 09, 2009 - 11:03 AM
No modifications are required. The OEM exhaust systems between the 98-02 400/426 YZs and WRs will freely interchage between bikes.
If you found you had to modify the mid-pipe bracket, then either the subframe was bent or the pipe was bent.
