99 YZ400f Clutch Question
3 replies to this topic
  • ryan2214
Posted June 08, 2009 - 10:57 AM
Is there any way to adjust the clutch internally? I put a brand new cable on and I can't get the clutch adjusted right, it engages way too soon. By the way I had the clutch plates replaced not to long ago. One more question: what are the best things to make the bike lighter? As you all know these things are heavy beasts, but there has to be a few things I can do to make it lighter.
Thanks in advance,
Ryan
Posted June 08, 2009 - 12:45 PM
There's no internal adjustment. Do you have excessive free travel at the lever? (more than 5mm?)
Look for a second adjuster, either at the engine end, or near the lever end, under a rubber sleeve.
  • ryan2214
Posted June 08, 2009 - 04:56 PM
I will have to measure, but the problem is the clutch engages way to soon and when looking at the lever that comes out of the engine, I am barely using any of the clutch (from what I can tell when engaging the clutch). It's almost like the lever on the engine needs to go back farther so when I pull the clutch lever it will pull if forward farther. If that makes any sense.
  • YzKaos2283
Posted June 19, 2009 - 11:09 PM
Check the adjustment at the location where the cable meets the clutch-pushrod lever. Where it bolts to the hanger, try to take most of the cable slack out there before adjusting at the lever.
  • Hot  28 replies
  • Hot  30 replies
  • 10 replies
  • Hot  38 replies
  • 0 replies
