bike ran for a couple hours then died
4 replies to this topic
  • mjenkins
Posted June 07, 2009 - 04:55 PM
bike has been hard as h@#l to start the last few rides,once started for the first time it starts fine the rest of the day,then went out the other day for a couple hours,bike ran perfect then exhaust note changed slightly started sputtering then stalled and wouldnt start....still cant start it.need help have to get back on trails thx in advance..bike is a 06 yz450f special edition
  • 426 NOOB
Posted June 07, 2009 - 05:09 PM
check your cam timing. Your timing chain may have jumped a tooth.
  • mjenkins
Posted June 07, 2009 - 05:40 PM
thx 426 NOOB....does this affect the starting problem as well?
  • Mav_10
Posted June 07, 2009 - 06:06 PM
I've hear this jump the tooth theory a bunch of times....are the chain tensioners that poor in keeping everything together??? That is very troubling.
Posted June 07, 2009 - 07:27 PM
Don't overlook checking the valve clearances.
The trouble in the late models appears to start with the chain stiffening. This causes the chain to be artificially tight on the slack side and prevents the tensioner from advancing. If any event such as a kick back or stall occurs that puts a load on the chain with this inadequate tension on it, it slips. Replace the chain annually and you should not have a problem.
  • On January 15, 2017
  • Hot  36 replies
  • 0 replies
  • Hot  113 replies
