What year did Honda fix the valves on CRF450r?
Posted 06 June 2009 - 05:47 PM
Posted 06 June 2009 - 05:54 PM
Posted 06 June 2009 - 06:00 PM
Posted 06 June 2009 - 08:13 PM
07 they went with a smaller exhaust valve for better low end. 06 they changed the valve seat material. Otherwise it has always been Ti intake, SS exhaust from the factory.
You are probably thinking of the 04 250R bikes
Posted 06 June 2009 - 08:58 PM
Posted 06 June 2009 - 10:55 PM
FZ1426 said:
+ 1
My '05 had about 1/4" seat material missing on an exhaust valve. The coating on the TI valves wears off causing need for shim adjustments.
S.S. does not have this issue but they are heavier require stouter springs and do not rev as quickly.
I replaced with an '06 head and full Kibblewhite S.S. It is on a street sumo 450R. No adjustments and 500+ miles thus far.
my .02
Posted 07 June 2009 - 07:55 AM
Posted 07 June 2009 - 08:05 AM
scientoothical said:
he's right.....the issue's in the past and present are due to operator error
Posted 07 June 2009 - 08:07 AM
crf-f crf-r trx cbr said:
Sure.
Posted 07 June 2009 - 08:19 AM
Do you work for Honda?
Posted 07 June 2009 - 09:30 AM
Posted 07 June 2009 - 09:42 AM
The 04 crf250r is the honda that had valve issues
the 02 450r had airbox sealing issues, but the whole motor and carb is going to get damage from that. has nothing to do with the valve train.
I am sure that most people do not change the valves and piston per the manufacturer's scheduled maintenance. Yes it is a bit agressive, but it is what the manufacturer designed the engine to be reliable. So you trail riders that put 100s of hours on top ends are way past the expected life time of the motor. These are race bikes and thus have an increased maintenance schedule. if you did not want that, then stay with a 2 stroke or the XR/CRF-F lineup of products.
Not many engines on the planet can turn the HP and RPMs of the modern 4 stroke race bike and have a long life span. They turn 2x your Chevy SB does or acura. Only cars like the Ferraris can spin upwards of 9K, but look at their maintenance schedule! It is not your $20k car that only needs a 100K tuneup.
I see the original poster has had good luck with his Yamaha. Great. But the 06 YZ250f bikes were recalled due to valve issues. I dont see you shying away from yamahas. Keep that in mind.
Posted 07 June 2009 - 11:18 AM
The 06 Yamis did have valve issues. But Yamaha did a ASAP recall replacing all units free of charge. They didn't deny the issue, they fixed it ASAP. And not even all 06s had the issue, just certain vin's. There's many aspects I like about the CRF line, that's why I'm reconsidering these bikes. But they'er not superior in terms of the RPMs they turn or their race performance when compared to other mfgs, such as Yamaha, yet their maintenance seems higher with regard to top ends: ie, pistons, rings, valves, etc. I enjoy working on bikes, but enjoy riding them even more. And I totally agree about maintenance being a must. This is good info and I appreciate it. I'll keep doing my research.
Posted 07 June 2009 - 11:38 AM
they may be getting better, but they are far from as good as some other bikes.
I am meticulous with my 06 as far as maintenance goes... cleaning air filters and inspecting/adjusting valves... the valves on my bike started moving at around 75 hours and haven't stopped. I've seen tons of other people on this forum with the same issues... doing top ends every year or every other year...
my previous yamaha's and current ktm needed few if any valve adjustments... same goes for my buddies yamahas and KTMs, all high hour, hard ridden, bikes, of all sizes.
I love my honda, it's my primary bike, but you can't deny the valves on these guys just don't last as long as the competition.
Posted 07 June 2009 - 01:01 PM
+1 along with both of these gentlemen,letting dirt through to the intakes sandblasts off the hardcoating.New stock valves and springs with a proper valve job by someone that knows what they are doing and probably new exhaust guides and a good stock air filter and nasty pain in the ass airfilter oil with proper cleaning= no "valve issues".cheers
Posted 07 June 2009 - 01:16 PM
Posted 07 June 2009 - 01:20 PM
Posted 07 June 2009 - 01:24 PM
gruberyz said:
Haven't heard of that one yet. Hopefully that doesn't ring true for me. Although, I did have my cases apart a while back & everything looked fresh.
