head gasket
3 replies to this topic
  • keith_king
Posted September 07, 2002 - 02:05 AM
im replacing my head gasket and in the owners manuel they say you need to replace these 4 "crush washers" i have the gasket but the washers will not be in till tuesday and I WANT TO RIDE do any of you guys know if i have to replace them? or do they just recommend it? thanks guys
  • hsstar
Posted September 07, 2002 - 03:33 AM
If these crush washers are sealing the oil lines they will most likely leak. It they are the washers on the head bolts they can be used over and over.
  • MX_Tuner
Posted September 07, 2002 - 01:43 PM
Which crush washers are you referring to? If you're talking about the ones that seal the external oil line, I've had good success reusing the old ones. As a general rule, all manufacturers recommend replacing *any* sealing washers.
  • AZWR426
Posted September 08, 2002 - 07:05 PM
Roger That on the oil o-rings,washers. I bought new ones for my first oil change but when I took the filter housing and oil lines off they looked fine. So I reused them figuring at most they would weep a bit. And not even a drop ever formed so I guess it's just Yamahaha's way....
