Another leaky coolant thread...
4 replies to this topic
  • dankman
Posted June 03, 2009 - 12:32 PM
but its not the weep hole on the water pump cover...
looks like it is coming from the tube that connects the upper left side radiator hose to the head...looking at the parts diagram, it looks as if there's an oring there, and that may have gone bad...
my question is, anything else that can be causing the leak?
Posted June 03, 2009 - 02:22 PM
Bad seal, or rust-through on the steel tube.
  • jayfox911
Posted June 04, 2009 - 11:47 AM
I had the o ring go bad on the y pipe going to the water pump area.
so yeah replace the $2 oring and you should be good. i waited to long and it started to drain out after about 2 rides of weeping. the oring split in to two under the pressure.
  • dankman
Posted June 04, 2009 - 02:18 PM
yeah...got the oring yesterday and going in today...hopefully that's all it is...
  • dankman
Posted June 04, 2009 - 08:34 PM
oring replaced and all is good...thanks.
  • Hot  36 replies
  • Hot  47 replies
  • 0 replies
  • 3 replies
  • Hot  113 replies
