Running weird.
5 replies to this topic
  • chevy power
Posted June 01, 2009 - 10:51 AM
Ive made a few threads about this bike. Ive got the carb dialed in, I have a slight back fire on decel no bog or hesitation though. I went riding saturday, rode some trails and hit the track for the first time. After a half day of riding the thing died out. It acted like it was running out of gas, I checked the tank breather, and the normal things. I rode it today around a field by my house, once it gets hot it dies when you give it gas, it will idle and die if you give it any gas above idle.
I think it might be the valves, I have adjusted them and they were in spec before the last ride, its an 03 so I have a feeling it might need some head work, I did how ever look at the head and the valves appeared okay from pics I have seen on the site.
Jetting is.
50 pilot
165 main.
4th clip on needle and 0-3000ft elevation im in ohio.
Any things I should try to check out, I will check the valves after it cools down. But im looking for some suggestions on what could be going on.
  • William1
Posted June 01, 2009 - 11:43 AM
Sounds like it is electrical - in order of probability:
Crank position sensor
  • chevy power
Posted June 02, 2009 - 01:03 PM
Im not seeing the crank position sensor in the book.
  • chevy power
Posted June 04, 2009 - 09:36 AM
The valves checked out good, and the coil I dont think my ohm meter has the correct value to check the secondary coil resistance. The primary checks out okay, I cant get continuity on the first one at all. And the CPS I cant find. I will tear into the carb again to double check that.
  • Krannie McKranface
Posted June 04, 2009 - 03:36 PM
  • chevy power
Posted June 06, 2009 - 05:59 PM
I swapped coils with my buddy from his YFZ. Figured the problem out its the coil, secondary coil resistance is the same hot/cold on both of them. I still wasnt able to get a reading for the primary resistance (damn meter).
