What rear shock do I have (02YZ426F)
3 replies to this topic
  • rufusz
Posted May 31, 2009 - 09:49 PM
Hi,
Could someone help me out with identifying my rear-shock absorber. The bike is an 02 YZ 426F and I got with it a WR400 service manual, which is more/less the same. It showed for the rear-shock absorber to have both a low- and high- compression adjuster. I've thought it was a WR shock, and my is YZ. But now I've checked in the YZ manual, and it shows the same. My rear shock looks the same (as in manual) but doesn't have the outer high compression adjuster.
Will try to post pics asap if that helps.
Thx
Posted June 01, 2009 - 06:54 AM
There is not a hexagonal ring around the compression adjuster on the top of the shock?
  • rufusz
Posted June 01, 2009 - 10:20 PM
Nope. It has only 2 flat sides, other 2 are round and the brass adjuster is in the middle.
This is my ride:
http://www.thumperta...938#post8113938
Will post a close-up also.
Posted June 02, 2009 - 09:52 AM
The 1999 YZ400 had a shock that had a low speed only compression adjuster. The fitting with two flats instead of 6 houses the high speed piston, as with the later shock. According to my info, your bike should have had a high speed adjuster as well.
  • Hot  36 replies
  • Hot  33 replies
  • 0 replies
