  • Instagram
Related Garage
Kawasaki KLX110L (2010)
Owner: bdub_24
Added on February 29, 2016
Related Reviews
Kawasaki KLX110L 2014
No reviews available
Be the first to review this
Suzuki DR-Z70 2013
Suzuki DR-Z70 2015
Kawasaki KLX110L 2016
Suzuki DR-Z70 2016
Free and easy klx 110 mods
  • Please sign in to reply
9 replies to this topic
  • thevat0
Posted May 31, 2009 - 04:50 PM
So heres the scenario: you bought a klx 110 and figured out that you dont want to take out a second mortgage for your pitbike. I had the same problem. At 15, with no job i dont have alot of money kickin around. I bought new front and rear sprockets, geared for power, and didnt wanna put any more money into the bike. here is my solution:
For power:
Exhaust:
I took the exhaust pipe off, but it backfired alot, and didnt sound right, so i put it back on. It does however give you a noticebale power difference. im not sure if this damages your motor. I am currently working on a homemade exhaust mod and will keep you posted.
Air filter:
dont waste $150 on a bbr filter. do this:
1:take off the left radiator shroud, and remove airbox, and the hose connecting it to the carb.
2:take the airbox apart and take out the rubber piece with the 2 holes for air. there is now an oval shaped hole.
3: take a file or a grinding drill bit and grind the hole to your desired size. then put the airbox backtogether MAKE SURE YOU LEAVE OUT THE RUBBER PIECE WITH THE HOLES,
4: Put the hose into the airbox (this is a little tricky) then bolt it back in and put the other side of the hose into the carb.
5: play around with the jets till you find what works.
The whole process is fairly simple, took around 30 minutes and has a noticeable power/top speed increase, and it sounds cool.
I have read that removing the choke will give it less air constriction, but have not done this yet. When I do I will put the steps on here.
For the pitbike look:
Remove:
-chain/sprocket guards-looks so much better - but make sure you dont get your pants or shoelaces caught in them.
-kickstand
-rubber piece off the kick starter
-rubber piece off shift lever
-rubber chainguard on stock swingarm
Move the brake lever to the left side of the handlebar (unless you installed a clutch kit) but first you will need to move the run/off switch: i took mine off the bars, then put it back together, then slid a cotter pin throught the back bracket so it was beetween both pieces. there is a little hole in the frame near your airbox, behind the left radiator shroud. i slid the cotter pin through there, from left to right, and bent the ends on the right side. This looks cool and keeps it out of the way so you dont bump it off while riding.
Tall seat:
You could buy an aftermarket tall seat, or you could save $120 and make one yourself. How?
1:take the seat off
2:take out the staples holding the cover on.
3:take your foam (i stole mine from my dads bed, mattress foam works well) and use a little tape to hold it in place- note: you dont want it to go all the way down, just on the top
4:restretch the cover over the seat and staple it back on. I ran out of staples but duct tape works just as well
5:done
**My rear fend was broken from dumping the bike during a wheelie. again, save yourself some money and dont buy a new one. beetween steps 2 and 3 i went out in the shop, cut the fender across the broken part, put it on the drill press and drilled 4 holes through the seat and the fender. then bolted it on.
Plastics: Instead of buying a $100 plastic kit I painted them black.you need a special paint that will not chip when the plastic flexes. I dont remember what its called, but go to your local NAPA and talk to them about it.theyll know what its called, and sell it to you.
*if you fall alot i suggest not doing this, as the paint will scrape off and look bad.
Wider footpegs/heavy duty foot peg mounts:
Doing this will save you around $200 and is a must for big riders and if you do jumps. The only difference beetween the stock footpegs is the longer screws and wide footpegs. for the screws go to NAPA (I suggest making 1 trip not 3 or 4) and get some screws that are larger then the stock screws that hold the footpegs on. dont worry, if the are too long use some washers to make it work. before you put them in you may want to put some JB weld glue on them, but be aware that if you do this the footpegs will be stuck there for, well, ever. for the footpegs you can take some long bolts, and cut the threaded ends to the length of the footpeg, then weld them, a little lower then the footpegs so you dont lose notches for grip. this will feel a little bit more secure.
As i do more mods i will post them on here. Hope I helped everyone!
  • thevat0
Posted May 31, 2009 - 04:55 PM
Doing the mods above saves around $600 over buying them online.
I am working on another mod that involves puting round dowels into the forks, to see if it gives the suspension more travel. If it works, it will save around $170 because you dont have to buy stiffer springs and a new dampening rod
  • weantright
Posted June 03, 2009 - 01:16 PM
Remove and cap the choke. Need the choke, lay the bike on the side for a while before you start it cold. Correct jetting and you don't need a choke unless you fall into the low 30's. Toss the back fire screen and the stock air filter. Get a Twin air and use injector oil and coat it lightly. Will need to go up about 2 jets for these mods. I did just about everything to a stock pipe and a PC Ti-4 I have runs alot better. Pulls past a piped 2009 TTR110, a stock or modified pipe will not do this.
  • thevat0
Posted June 03, 2009 - 05:56 PM
yes all that is true but it also costs money. Im doin mods that can be done with spare parts & tools, and trying to help other people with the same problems, but thanks for the imput.
  • txkawboy
Posted June 12, 2009 - 11:00 AM
Hey man, just cut your springs to increase their rate, usually ~5 coils is all you can do. Make spacers to make up for the missing length out of PVC pipe. I have an article on this and many other $aving tips, posted on dirtrider.net, PM, and I think on here too. Cheers!
  • thevat0
Posted June 13, 2009 - 06:08 AM
thanks man
  • simmersm
Posted July 17, 2009 - 11:24 AM
wow... thats all i am gonna say... gonna walk away from this one...
  • DrD, letsgoriding and turbo dan like this
  • Like This
  • reblime13
Posted April 09, 2015 - 11:44 AM
Tall seat=$31.99 NOT $120
Tb air filter=$28 NOT $150
Plastics=$31.40 NOT $100
I don't know what crook is selling you bike parts....
  • facethenorth
Posted May 14, 2015 - 11:43 AM
Drill out the restrictor from the head of the exhaust pipe, you'll get a bit more power. I recommend putting in the spacers for stiffer springs, dampening won't change though. It's a pain to get the clip out and be careful the cap doesn't fly out and hit you in the mouth when you get the clip out.
Edited by facethenorth, May 14, 2015 - 11:45 AM.
  • letsgoriding
Posted November 26, 2016 - 09:13 PM
The same crook giving mod advice. lolol Hysterical thread.
Kawasaki KLX110 2015 by Chris.GVS
  • 0 reviews
Kawasaki KLX110L 2015 by Chris.GVS
  • 0 reviews
should I sell by yz250f616
  • Hot  25 replies
Suzuki DR-Z70 2014 by Chris.GVS
Suzuki DR-Z70 2014
  • 0 reviews
Suzuki DR-Z70 2015 by Bryan Bosch
Suzuki DR-Z70 2015
  • 0 reviews
