YFZ crankcase cover?
2 replies to this topic
  • rich1167
Posted May 31, 2009 - 04:25 PM
I have a 05 wr450 with a cracked left side crankcase cover. It's the side with the starter and stator. Any won know if one off a 04 YFZ will fit. The first 3 leters of the part # are different. (The YFZ is 5TG, and the WR is 5TJ) But by apperance the only differance is that their is a crankcase vent tube above the starter gear on YFZ. Any help or advise would be appreciated.
  • TwIzTeD NuTz
Posted June 03, 2009 - 05:02 AM
In order to use the YFZ stator cover on your WR you would have to swap the cover, and left case half. Everything else is the same.
  • rich1167
Posted June 03, 2009 - 06:09 AM
Thanks, I have already ordered the proper WR parts.
