sputter !!
5 replies to this topic
  • ThumperWR450F
Posted March 13, 2003 - 02:49 PM
i am having a 1/4-1/2 throttle sputter. after that it's fine. any suggestions? 160 main 48 pilot. snorkle removed baffle removed. sea level.
  • Indy_WR450
Posted March 13, 2003 - 03:47 PM
I get that after I wash it if the filter gets wet. May be water in the airbox? Otherwise drain your tank and put in fresh high test. Since it is between 1/4 and 1/2 throttle only I doubt it is a spark plug or ignition problem. I doubt your carburator is gummed up anywhere but if the above dont work take apart and clean your carb. :)
  • HighPlainsWR
Posted March 13, 2003 - 06:47 PM
Yo Thumper. Had the same issue with my WR450. I first richened up the pilot by adjusting, of course, the pilot adjustment screw. But still I had too lean a condition with the 48 pilot, even at 5K ft. I had the dealer go to the next higher pilot jet, 50 I think, they adjusted the fuel screw, and bada bing - no sputter. At your altitude just richening up the 48 circuit should work.
  • Oasis_Flame
Posted March 13, 2003 - 08:11 PM
Clean the accel. pump. Mine did same until I cleaned it, problem gone!
  • Indy_WR450
Posted March 14, 2003 - 02:38 AM
I will keep that in mind Oasis_Flame. I have yet to get the carb dirty but I have heard that even the smallest insignificant particle can give you funky carburation.
  • Rich_in_Orlando
Posted March 14, 2003 - 10:22 AM
Raise (richen) or lower (lean) the needle 1 clip position and see what happens. 1/4-1/2 throttle response is mainly controlled by the needle. If what you mean by sputter is what I think you mean, I'll bet you need to lean it a clip.
