1st post to the yf450forum
11 replies to this topic
  • sconeracing
Posted May 29, 2009 - 01:03 PM
i love my new bike, but it will take some time to get used to it
Posted May 29, 2009 - 01:49 PM
You can actually do the yellow plastics if you just can't let it go that easy. The '06 stuff for the 50th Anniversary model bolts right up.
If you're setting up for off road, you'll want a skid plate. Devols are pretty good (I have two), and fairly cheap. Scorpion make that has a little better side case coverage. Then there's Lightspeed.
A Scotts damper isn't as necessary as it would have been on your RM, but they are very hard to do without once you've run them for a while.
  • Wiz636
Posted May 29, 2009 - 02:26 PM
Hey Scone, not much is needed on the Yami's. You already got rid of the POS sprocket eating stock chain so you are good there. Yamaha has the carbs dialed in pretty good now so you should be okay there also...I have been running the stock jetting and needle position all the way around...just need to go up on the pilot jet when winter rolls around.
  • trav
Posted May 29, 2009 - 02:28 PM
are YZs better than RMs?
  • sacfelix
I would also look into a fly wheel weight.
  • Wiz636
Posted May 29, 2009 - 02:36 PM
I should have mentioned that getting your race sag dialed in makes a big difference on these bikes.
  • trav
Posted May 29, 2009 - 02:39 PM
how fast is a YZ? I might get one if they are really fast.
  • Wiz636
Posted May 29, 2009 - 02:56 PM
Oh, you definitely want to re-route your breather tube! Take a look at mine next time we ride.
  • Ministry
Posted May 29, 2009 - 04:04 PM
No they are pretty slow. Stick with your Katoom.:crazy:
  • trav
Posted May 30, 2009 - 08:58 AM
OK THEN I AM BUYING AN RM! I HEAR THEY ARE FAST. MY KTM IS ONLY A 250 AND I NEED A FAST 450 4-STROKE
  • spc mike
Posted May 30, 2009 - 10:36 PM
Are you kidding me?:crazy: from reading your post's It seems like you are a 13 year old kid....and stop YELLING!
  • TIG88
Posted May 31, 2009 - 08:50 AM
I was gonna say the same thing. No way that guys 32...:eek:
  • On January 15, 2017
  • 10 replies
  • Hot  38 replies
  • Hot  36 replies
  • 0 replies
