Back in business !!
7 replies to this topic
  • ThumperWR450F
Posted March 13, 2003 - 01:09 AM
Well i finally got a new woodruff key for my bike.i retorqued to 47 lbs and loctited it. i put 25 miles on it so far no problems yet knock on wood . my first key went at the 14 mile mark.
  • The_Blue_One
Posted March 13, 2003 - 06:44 AM
I would check it every so often.I had 110 miles on mine till it broke and think the flywheel was still seating.My dad said the old huskies were the same way.
  • Indy_WR450
Posted March 13, 2003 - 07:42 AM
If you torqued it down with red loctite on the taper and the thread don't bother checking ever again unless you suspect it failed. You are going to bend your pullers getting that flywheel off. :)
  • sjw
Posted March 13, 2003 - 11:19 AM
Indy,are you saying dont mess with it if you havent had any problems? I have almost 200 miles on mine,runs great.should I ever check it?
  • MxnDoc
Posted March 13, 2003 - 07:26 PM
No problems here with 126 miles....anybody else checking or leave it alone until it becomes problematic? :D :).
  • The_Blue_One
Posted March 13, 2003 - 08:27 PM
I checked mine after 100 miles after it broke the first time then again after another 100 miles.No movement and i'm done checking.
Sorry if i confused Anyone. :)
  • Indy_WR450
Posted March 14, 2003 - 02:35 AM
SJW,
I think there were some under torqued units with some marginal taper fits. I checked mine after every ride and stopped worrying about it. I will check it once a year from now on.
  • Burnrider
Posted March 14, 2003 - 04:56 AM
WRF riders: I have been watching this flywheel shear on the forum for some time. I had old Huskys and Bultacos with massive aluminum flywheels. I never sheared a key or heard of one being sheared. How big/or heavy is the flywheel on the WRF and what size is the actual threaded end of the crank?
I just read "WOODRUFF KEY FAILURE AFTER LAPPING". I think I get the picture. I hope you guys can get it solved without replace the crank or the rotor. It sounds like a manufacturing problem. It may take some time to sort this out at the expense of the rider to different degrees.
