Losing Gas When Bike is on Side
3 replies to this topic
  • jams229
Posted May 28, 2009 - 12:25 PM
I have a 2007 WR450. Just curious, has anyone rerouted the gas line so gas doesn't spew out while the bike is horizontal. (I spend quite a bit of time on my side... especially when bull dogging down a cliff, or, resting after a get-off.)
Thanks.
  • getndirty
Posted May 28, 2009 - 12:30 PM
Carb floats don't work when the carb is turned sideways, since the needle valve isn't closed it's going to keep allowing gas to flow into the bowl and out of the overflow.
If you're going to be bull-dogging down a cliff with the bike off, turn the gas off before you go - same if you like to lay your bike on its side when you're resting.
  • SJMC_DON
Posted May 28, 2009 - 12:48 PM
TRUE DAT:thumbsup:
  • jams229
Posted May 28, 2009 - 05:41 PM
Thanks - that's what I thought, but I wanted to make sure I was not missing something. I used the word "resting" liberally. Basically means after I crash I don't always bounce right back up...:crazy:
