Results of 13 tooth countershaft sprocket?
8 replies to this topic
  • tma
Posted March 12, 2003 - 12:06 PM
Has anyone changed the front to a 13 and left the rear stock? What was the net result?
I find myself between 1st & 2nd in the twight twisty rocky stuff and would prefer to remain in 2nd. Any Feedback (other than learning to ride faster)?
Thanks!
Tom
  • Dutch
Posted March 12, 2003 - 02:58 PM
I run a 13/50 combination last summer and it worked well in the tight Michigan woods. 3rd gear is a blast ----
  • Matt96xr6
Posted March 12, 2003 - 08:10 PM
13/50 is what I ran on the xr6 and same on my kdx250
Seems to be a great gearing to pull 2nd all day long in
  • qadsan
Posted March 13, 2003 - 06:21 AM
I found myself between 2nd/3rd too often on various desert trails, so I switched to 13/48 a and I really like it.
  • tma
Posted March 13, 2003 - 07:13 AM
Thanks for everyone's input!
I'll be tying a 13 tooth this weekend...
Regards,
Tom
  • jaybert600
Posted March 13, 2003 - 01:42 PM
I had the exact same problem- too much time in 1st gear in the slow stuff. I went to a 13T front sprocket with the stock 48 rear and solved the problem. Best part is that a front was $15, instead of paying $50+ for a new rear sprocket.
  • qcustom
Posted March 13, 2003 - 02:28 PM
I have a XR650R with power up and I right tight north MI. trails I had a 14/50 loved it good power out of turns in 2nd then went to a 13/48 ok but I liked the 14/50 better doesnt seem to lug as well out of turns if i were to do it again I would do a 14/51.
  • Portland_650R
Posted March 13, 2003 - 03:06 PM
I use a 13/50... it was the only way to get into second in the woods. So far, so good, no chain stretch or huge wear issues (but then I don't ride nearly enough!). If I pin the throttle in first gear on the pavement, I CAN'T keep the front wheel down. What a hoot!
  • tma
Posted March 18, 2003 - 06:04 AM
Well gang, I rode with the 13 on Sunday and loved it in the tight stuff! I was able to run 3rd most of time and only dropped into 2nd in the real nasty areas. 3rd is a blast!
Thanks for everyone's feedback.
Tom
  • 0 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
  • 3 replies
  • 17 replies
  • 2 replies
