Oil getting past decompression plug hole after hotcams mod
3 replies to this topic
  • MTS II
Posted May 24, 2009 - 09:41 AM
Did the hotcams mod and plugged the decompression hole with one of the plugs off of eBay. After the first ride yesterday I noticed that oil is getting past this plug it appears. Could the o-ring seal on the head be damaged? Seems to happen after riding for at least 30 mins
Thanks for the tips!
  • 642MX
Posted May 24, 2009 - 11:19 AM
You need to replace the seal. It probably got torn while removing the decomp lever.
  • 02WR426Cali
Posted May 24, 2009 - 11:44 AM
I think you take the seal out when using one of those plugs. The plugs use an o-ring I believe. I just got a new seal and cut up the stock lever to make it look like a plug when I did mine.
Posted May 24, 2009 - 12:12 PM
There are two versions of the plugs made for that hole. One uses an O-ring and requires the original seal to be removed. The other uses the OEM seal as the shaft did. How you correct this leak depends on which setup you have.
