Squeaking in TTR-125 rear suspension?
6 replies to this topic
  • Aossowski
Posted 24 May 2009 - 06:05 AM
Everytime i sit down on my bike it squeaks. It's coming from the rear shock.  I'm not sure what to do from here on.  Should i take the bike apart and clean/grease/lube everything up? Anything help appreciated!
  • Gani_riders
Posted 24 May 2009 - 06:13 AM
wouldnt hurt. It did it to my siters 80 once i just sprayed some lube in there as a temporary fix.
  • YamaLink
Posted 24 May 2009 - 07:51 AM
It is a good idea; make sure you properly torque the pivot bolts/nuts when all is said and done.
  • Chickenhauler
Posted 24 May 2009 - 06:17 PM
Yes, but insert "inspect for rust/deterioration of the bearings" immediately after "take bike apart"....the bearings are probably toast.
  • se376th
Posted 25 May 2009 - 04:22 PM
just spray some deep penetrating lube or even just wd 40 around the shock and swingarm. if this doesnt help then you may need to replace the bushings.
  • scalejockey
Posted 25 May 2009 - 04:30 PM
This is the last time i heard a squeek in the rear of my bike..
  • Aossowski
Posted 21 June 2009 - 06:47 AM
Thanks everybody! I took the rear linkage apart and found the bearings dry. I greased them up and everything is running smooth.
