03 wr450 whining noise
7 replies to this topic
  • knuckleduster271
Posted May 23, 2009 - 03:01 PM
My bike has developed a "whining" noise that increases as the rpm's get higher. It never done this before nor do my friends wr's do it. It's not a knock or a tap its just a high pitched whine coming from the engine. The engine doesnt have very many hours on it. Any help would be greatly apprieciated.
  • knuckleduster271
Posted May 24, 2009 - 10:45 AM
any ideas????
  • PBDBLUE
Posted May 24, 2009 - 02:52 PM
By chance did you recently put a skid plate on it. If so you'll hear all kinds of mechanical noises you never noticed before. Just a thought.
  • knuckleduster271
Posted May 25, 2009 - 04:50 PM
no skid plate, this is a noise that it has just developed in the last week.
  • BEAN329
Posted May 25, 2009 - 05:06 PM
a coupe of questions, does it do it sitting still, or when moving. Did you do anything with the air filter or subframe. did you just change the oil.
  • DrzDasher
Posted May 25, 2009 - 08:49 PM
Are you sure it isn't a chirp? If it is more like a high pitch chirp coming from the engine area, it is the carb. Other than that I don't know.
  • knuckleduster271
Posted May 26, 2009 - 07:00 AM
It does it all the time, its is a whine similar to a turbine or a car with a gear drive in it. I can tell for sure its in the engine. Last night while trying to diagnose it I saw that my water pump has a slight leak. Think this could be the problem? I havnt done any recent maintenence either.
  • ncampion
Posted May 26, 2009 - 09:38 AM
Fix the water pump and see if it goes away. You will have to do the pump anyway, could be the cause.
