O Ring
3 replies to this topic
  • MrLee
Posted March 11, 2003 - 07:51 PM
I took the carb completly apart a few days ago(99 WR400). I just noticed a tiny O Ring on the work bench. Didn't see it when disassembling the carb. It is not one of the accelerator pump O Rings (this one is even smaller then the smaller of those two) or the Air Cut Valve O Ring. The only thing I can see in the service manual is it looks like the pilot screw has a spring, possible washer, and an O Ring. I only have the spring. Any ideas other then I should not have taken it apart in the first place?
  • MrLee
Posted March 13, 2003 - 07:49 PM
I think I figured it out. Can someone verify that the pilot screw has a Spring, Washer, and O Ring? And the pilot jet has no washer or O Ring? I had the two mixed up after taking them off and placing them on labled sticky notes. Thanks in advance. 74 degrees today! What a time to be messing with the carb.
  • Oasis_Flame
Posted March 13, 2003 - 08:07 PM
Thats where it goes. Local hardware store has that size if you need a new one.
  • MrLee
Posted March 14, 2003 - 06:59 AM
Thanks for the reply Oasis. I appreciate the help.
