Stator / Rectifier / Fan Wiring
3 replies to this topic
  • buzzfin
Posted May 22, 2009 - 01:35 PM
Ok, so I have a new lighting stator from ElectrexWorld installed on my '09 450. Not going to run lighting, but will be installing a cooling fan. Need to make sure I've got the wiring correct first... I picked up a regulator/rectifier from Trail Tech, however it has two yellow wires which are supposed to be run to the stator, but the stator only has one yellow wire. Should I leave one off or connect both to the single, yellow stator wire?
Also, Trail Tech says not to connect the black wire to frame ground, but to connect it to a "floating ground". Do I need to tap into the ground on the harness that comes out of my stator (which connects to my bike's CDI) or just simply connect it to the negative terminal of the cooling fan?
Thanks for your help, guys!
Posted May 22, 2009 - 02:14 PM
You can't go by the wire color when the products come from two different manufacturers. You also cannot connect any part of either your new lighting coil circuit, or the DC circuit that comes from the rectifier to either the frame ground or any ground lead in the YZ wiring harness. Your added on electrical circuits, including the fan ground, will have to be kept separate and isolated from the AC system that operates the YZ ignition.
  • buzzfin
Posted May 22, 2009 - 02:29 PM
Ok, I get it..... Attaching the rectifier or fan ground to the wiring harness ground would cross the AC and DC grounds. Makes total sense now. I'm thinking the easiest thing would be to just add a battery or capacitor and connect DC ground to that... Wouldn't that do the trick?
Posted May 22, 2009 - 02:40 PM
That should. Just keep the circuits apart from one another.
  • Hot  113 replies
  • On January 15, 2017
  • Hot  30 replies
  • 0 replies
  • Hot  50 replies
