suspension
5 replies to this topic
  • trey03
Posted May 19, 2009 - 07:51 PM
i have a 01 yz 426 what is a good suspenion upgrade thats economical i mostly ride trails with a little jumping not much or very high im still a novice rider would like to know whats available in suspension and whats best for me trail riding:busted:
  • wondermuscle
Posted May 20, 2009 - 06:50 AM
I would recommend installing the appropriate spring rates front and rear for your weight. They are easy to install yourself and only cost about $110 each new. But you might be able to find some used ones in the classified section on TT. Make sure to set the rear sag at about 90mm.
If you have a bit more money..... You should think about having someone re-valve the forks to take out the harsh mid valve that you don’t' want/need for trail riding.
  • spark250
Posted May 20, 2009 - 08:46 AM
you would have to give some more info here. how much do you weigh?
and put a $$$ amount on economical.
It would be free to or virtually free to first set sag, play with the clickers and move the forks up or down in the clamps. You could also add some oil to the forks if they needed to be slightly stiffer?
  • trey03
Posted May 20, 2009 - 08:31 PM
thanks for the advice i wiegh 195lbs stand 5 9' tall if that info helps
  • jjsmx
Posted May 21, 2009 - 02:30 PM
i just had my forks re-valved on my 426. they have never felt better. it was $150 parts and labor. stock springs are fine for me. i am 195 pounds and ride trails and mx tracks. i recommend it.
  • trey03
Posted May 21, 2009 - 06:15 PM
thanks for the info:thumbsup:
  • Hot  47 replies
  • 0 replies
