1999 wr400
1 reply to this topic
  • johnnys5
Posted May 19, 2009 - 07:40 PM
Just purchased a used wr400. I'm having problems when starting it cold. The choke doesn't seem to work. So I say "what the heck I'll pull the hot start for kicks" ...It start with the hot start pulled. Does anyone know what the problem might be?
  • matt4x4
Posted May 20, 2009 - 04:42 AM
sounds like your carb needs a good cleaning, make sure the pilot jet is totally cleaned up, once you get the starting procedure down, unless you left gas in the bowl for over a week it should start on the first kick if everything is set up right on it.
