what electrical symbol is this?
34 replies to this topic
  • Ca DRZ
Posted 18 May 2009 - 06:26 PM
the one circle in red
  • earthmx
Posted 18 May 2009 - 06:28 PM
ground
  • Ca DRZ
Posted 18 May 2009 - 06:37 PM
earthmx I don't think thats ground. but you may know more then me.
  • jmoliva00
Posted 18 May 2009 - 06:38 PM
Triangle is a amplfier & rectangle a resistor I believe.
  • 941MXVET
earthmx said:
ground
No.
Symbols of that nature generally designate a type of semiconductor. Your's looks to be a cross between a diode and a CMOS. I'll be able to look it up for you tomorrow while I'm at work as my references are all in my office.
  • Ca DRZ
Posted 18 May 2009 - 06:47 PM
941MXVET said:
No.
Great than i might find out why my lighting dose not work.
  • 941MXVET
Posted 18 May 2009 - 07:02 PM
If your lighting is out, and this is a factory part you might want to replace it anyway. It is used a couple other time in your schematic. I'm kinda interested myself in finding out exactly what it is.
An earler poster stated that a triangle usually designates an amplifier, and he is correct, but that would require 3 wires, so I don't think that's it.
BTW what kind of bike is it?
  • TDW
Posted 18 May 2009 - 07:13 PM
Dont know for sure but I would guess a diode of some kind, or possibly the symbol for a single wire connector. Was also wondering what component #5 is?
  • 941MXVET
Posted 18 May 2009 - 07:15 PM
I have a sneaking suspision... you may be right on this.
  • klxd
Posted 18 May 2009 - 07:19 PM
That's what I was thinking. Note that No. 5 in the upper right corner has two of them.
  • Ca DRZ
Posted 18 May 2009 - 07:25 PM
#7 in the pic is the cdi magneto I have not open the motor yet to look at the magneto. I'm thinking that what every that symbol is it will be found in the motor. The bike runs great just no lights.
#5 is the taillight
#1 is headlight
#2 is voltage regulator (new)
#10 is the light switch (new)
  • SDLineman
Posted 18 May 2009 - 07:34 PM
Flux capacitor? It's easy to check,just get it up to 88 mph to see if it's good. OK seriously, this kind of electrical system isn't quite my specialty, so I asked my electrical engineer wife what she thought, and she said, quote "I dunno." We broke out a bunch of books we both collected from school, and the best we could come up with is maybe a rectifier. It's not exactly like the standard symbol, but close. The single wire connector theory is good one too.
  • klxd
Posted 18 May 2009 - 07:40 PM
Usually there's a list of symbols at the beginning of the schematics in the manual.
Can't be a diode, the light wouldn't work.
  • wgeyer88
Posted 18 May 2009 - 07:52 PM
Single wire connector.
All the other wires have the 'clip-in' type plugs, with the exception of that wire and #5
  • TIM696
Posted 18 May 2009 - 07:59 PM
AMATURES
its an upsidedown triangle and rectangle
  • quailchaser
Posted 18 May 2009 - 10:15 PM
Based on the diagram and without having any key....#7 as you said, should be the ignition/lighting coil. The Yellow wire leading from #7 to the "upsidedown triangle and rectangle" should be the power for the lights from the lighting coil. That "upsidedown triangle and rectangle" should be a "bullet style" single connctor just like the two for the tail light.
  • davidl9999
Posted 18 May 2009 - 10:23 PM
+3 on single-wire connector. (maybe +4, I lost count...)
The rectangle is the female side, the triangle is the male side.
  • Coadster68
Posted 19 May 2009 - 10:10 AM
Its definately a connector, I talked to my computer/electrical engineering teacher (40+ years) and he confirmed it, theres really nothing else it could be.
  • William1
Posted 19 May 2009 - 10:51 AM
.....and the male symbol as a triangle is because guys are more stable.
Sorry could not resist. I cannot believe this thread is still going on
  • kc_450_X
Posted 19 May 2009 - 10:55 AM
I think you're right, it a single wire connection. The symbol for a diode looks like this.
