Trying to determine if the bike boots that clamp to the front tire of bikes are for me. Never used one.
Getting ready to purchase an enclosed trailer and originally planned on putting bikes front tires up against side wall e-track and strapping down with bikes steering locked and back end swung up against the other side of the trailer.
Started thinking about bike boots as an option however.
Problem is, I think that the boots need to be some distance from the wall in order for the lever to work. How much space? I'm thinking I still want a setup similar to described above so the boots would be somewhere between 30 and 45 degrees off of perpendicular from the side wall. Anyone know how much clearance the boot would need to be from the wall to get operation of the lever? I've sketched this out and I'm guessing 6"..... problem is if it needs to be that far off the wall then I can't get as many bikes in the trailer as with the pulling them up against the etrack.
Another thing that has me concerned about the bike boots is that since the bikes are sideways across the trailer is hard braking potentially going to rip the boots out of the floor? I can't guarantee that I'm gonna get the anchor bolts in a stud. Just seems a little sketchy too me intuitively about not having the boots in line with the trailer. Anyone have experience with this?
What are the downsides to the boots?
Anyone know? Any ideas as to how to set this up?
Looking for trick ways to deal with either the e-track or the boots. Need something to mount to the etrack to position front tire and also need a method for fastening down the rear tire with either setup.
Any problem with pulling bikes up tight to a side trailer wall up against hat channel studs w/ 3/8" plywood and etrack at bearing point of tires?
Anyone seen a setup where the etrack was more at the level of the handlebars so that the suspension wasn't loaded? I was talking with someone who had seen a setup like this that looked good. Also tied the rear tire to etrack on the wall at that level.
Any help?
