What's the easiest pulling clutch perch and lever set there is? I have the stock one, and its tough to pull after about 3 laps. I am working on hand strength, but was just wondering if there was anything out there that would help. Thanks in advance.
Easiest pulling clutch perch and lever combo?
Started by chasemotox63, May 18 2009 05:59 PM
16 replies to this topic
Posted 18 May 2009 - 05:59 PM
Posted 18 May 2009 - 06:09 PM
Moose makes an easy pull perch as well as an add on easy pull ratio reducer.
Posted 19 May 2009 - 05:11 AM
i recomend a hydrolic clutch kit. they are 200 bucks and never wear out. i love them. but if you get a new lever and perch get a new cable becasue you cable could be rusty or worn
Posted 19 May 2009 - 05:54 AM
MSR makes one called the pro raptor which gives three different positions of leverage. I used it a couple years ago for the same reason and it worked out well.
http://www.msrhp.com/
Posted 19 May 2009 - 07:16 AM
Not sure about the ones that move the mounting point on the lever for the cable end. If the top say's increased cable pull then common sense would tell you the bottom would be less cable pull meaning not disengaging completely.
I don't know, I could be way off here but it seems obvious.
Posted 19 May 2009 - 09:46 AM
Magura Hydraulic Clutch Best bang for the buck. It just takes a little getting used to. The pull is very linear and smooth.
http://shop.thumpert...p?p2=&s=2&p=611
Posted 19 May 2009 - 01:11 PM
+1
Magura...
Posted 19 May 2009 - 01:17 PM
i would say hydrolic clutch they are really easy if not i have asv'sand it ajusts for a shorter pul witch makes it easyer
Posted 19 May 2009 - 01:28 PM
For the easiest pull, you need to get the magura hydraulic clutch. I have bad tendonitis (arms/hands) and never had any problems riding after installing that clutch.
Posted 19 May 2009 - 01:56 PM
Buy a new clutch cable and maybe a new clutch lever/perch. You have a 125 (an RM even) and I bet the friction in an old dirty/dry cable/housing will cause the heavy feel. make sure what you have isn't just in need of service before dumping money on a hydro clutch.
$30 versus $300 hydro unit.... your choice. :)
Posted 19 May 2009 - 03:47 PM
Just fiited the Magura Hydro clutch to my 07 CRF 450. Night and day difference!!! GO BUY ONE.......................NOW!!!!!
Posted 19 May 2009 - 04:18 PM
I think I might go with the Moose Racing easy pull clutch system, because it's only $37, and most reviews make it sound like it really works. I can't afford a hydrolic clutch, and I'll probably only have my bike for the rest of this year, so it's not worth it. Thanks for all the help guys. :ride:
Posted 19 May 2009 - 04:39 PM
same here, does the moose racing one really work good? if you get it, let me know how it feels, i also wouldn't mind an easier clutch because i one finger the lever so my finger often ends up curling up and cramping - not fun.
Posted 19 May 2009 - 04:45 PM
Well, I've done some further researching, and now I'm not for sure, most people are saying that it doesn't work very well. But I have heard a lot of good things about that MSR Pro Raptor Clutch. I think I might get that, and a new motion pro clutch cable.
Posted 19 May 2009 - 07:21 PM
I was going to recommend this, so +1.
I have the MSR on my DRZ (not for the ease of pull, but for the fact it's a burly short lever), but it does make it considerably easier to pull.
