New indicators refuse to flash!!!
2 replies to this topic
  • moronofmudgb
Posted March 27, 2001 - 09:07 AM
Hello, can someone please advise me of what type of battery i should use for my WR400 00, and some tips on fitting would be great too!!! Thanks.
  • fershy
Posted March 27, 2001 - 09:17 AM
I use and recommend a powersonic 1208. Very compact and fits snugly inside your airbox. I took my airbox apart and riveted a small aluminum bracket to the inner wall. Wish I had a digital camera so you could see how sweet the install really is. A regular two prong flasher should do the trick. Run the power directly to the flasher then on to your handlebar switch. Viola! or as the french say
Voila!
Check out the powersonic 1208 here http://www.dcbattery...ower-sonic.html
fershy
  • Guest_Guest_*
Posted March 27, 2001 - 09:20 AM
I purchased a gel battery from baja designs. Its completely sealed. I did the same as Fershy w/ the airbox setup.
Nick
