How corrosive is VP Streetblaze 100?????
3 replies to this topic
  • bananbender
Posted 17 May 2009 - 08:25 PM
I read that oxygenated fuel is more corrosive than non oxygenated...
So VP Streetblaze 100 is oxygenated.
But how corrosive is it?
Do you need to drain it out of the carb, etc?
  • DieselSJ
Posted 17 May 2009 - 08:29 PM
It is oxygenated with ethanol. Most pump gas is oxygenated the same way.
  • bananbender
Posted 17 May 2009 - 08:34 PM
That means it is ok to not drain it -right?
thx
  • Dirtymutt9
Posted 17 May 2009 - 10:31 PM
if i believe correctly street blaze 100 is exactly the same fuel that is run in the ALMS championship. it is 10% ethanol by weight. unless you have components that are sensitive to ethanol, you should be totally fine.
