Well i thought i would go with the ATF type F in the tranny of my bikes. i did this for close to a year on my 95YZ125 and i think my 82RM250 restore has been finished for about 3-5 months.. first off it has to be changed every 2 hours or when the clutch slip starts to bug you......yz125==loose clutch basket gear rivits, badly grooved basket and boss. clutch just totally smoked... rm250==blew out 4th gear totally and 2 shattered clutch disks.... you can take this info how you like. no i don't want to argue about it.... and NO this was not the perfect controlled experiment.... but i',m never running ATF again:ride:
Can ATF cause transmission problems?
Posted 17 May 2009 - 04:21 PM
Posted 17 May 2009 - 05:24 PM
P.S. Wow you have a lot of schratnell to clean up.
Posted 17 May 2009 - 05:27 PM
Posted 17 May 2009 - 05:34 PM
and those have been around a while now too ..........................
so i'm thinking it something besides the fluids too .
Posted 17 May 2009 - 05:38 PM
Lets just say that you are going to change your oil about 10 times this year. If you use 1 quart on average each change, and ATF is $3 per (I think that it's about that... ?) and my Golden Spectro is at $8.50 per. This means that over the course of a year, you will save $55. But for the piece of mind and knowing that not only does my bike shift great, and the clutch is smooth with Spectro ~ I do not think that it's worth giving that up for the savings.
Please guys, I know that this can be a heated subject, with an equal amount of passion on both sides. So let's keep the bad gas out of this.
And let's not forget that my 2 stroke does not have a oil pump, a filter, and a cooler ~ like just about every auto transmission (car or truck).
Posted 17 May 2009 - 05:41 PM
Posted 17 May 2009 - 05:53 PM
Posted 17 May 2009 - 06:39 PM
And after more than twenty years of using ATF with no unusual wear and zero tranny failures, I just refuse to believe the ATF had any contribution to the OPs failures.
Posted 17 May 2009 - 06:56 PM
Posted 17 May 2009 - 07:00 PM
earthmx said:
Posted 17 May 2009 - 08:11 PM
Chokey said:
if you read the spec part of the hydraulic oil as compared to the atf there are quite a few similarities.
hydraulic oil comes in a 20wt as well.aw 48 would be equilvilent to a 10wt while an aw68 would be a 20wt.
Posted 17 May 2009 - 08:21 PM
Chokey said:
I agree. Those failures are not related to ATF. Believe what you want, but it is more than likely that you would have had those same failures no matter what you were running in your trans.
Posted 17 May 2009 - 09:44 PM
its basically just a better more expensive hydraulic oil , some people run it for hydraulic oil in machinery . most don't because its just cheaper to get hyd oil .
i always throw a liter the hydraulics to die it red so you can actually see it in the dam sight glass .
Posted 18 May 2009 - 03:12 AM
Posted 18 May 2009 - 03:25 AM
jeffgg said:
and now were on to something lol:lol:
Posted 18 May 2009 - 03:47 AM
jeffgg said:
lol finally someone said it.
i used to run gear oil in a TRX250R i used to own, i smoked 3rd gear and all clutch components. my conclusion: it was a 25 year old quad, not the wrong oil.
Posted 18 May 2009 - 04:09 AM
I like that argument that car transmissions have tighter tolerances than dirt bike transmissions. I've read that quite a few times on here, but would love to see numbers to back that up. Something like a backlash spec for gears, or just anything that can quantified and compared between the two.
Also, there are loads of cars out there that use ATF in manual transmissions and transfercases, straight from the factory. There goes the theory it won't work in high-shear applications. And we all know (or should know) that ATF is designed to work with wet clutches (bands). All in all it's a pretty ideal oil for motorcycle transmissions.
Posted 18 May 2009 - 04:32 AM
I've never seen any significant wear or had any problems. Change it at a regular interval and you will be fine.
