traded my extra bike for a jetski.. any jetski riders? i have ?'s
12 replies to this topic
  • yellowsnow
Posted 17 May 2009 - 03:59 PM
traded my 1995 YZ125 (fresh top end and like new OEM clutch assymbly) for a 1990 Kaw TS 650 jetski that runs good, looks ok, just needs the handle bars welded. came with good trailer. A guy off craigslist got ahold of me and we did a straight trade. do you think that was an ok deal? of course i still have my restored 82RM250 for the dirt. but i think the jetski will be good fun to take out with my old junky ski boat. any mantanance advice for jetskis?? since it is a 2 stoke does it need rings as often as a dirt bike? compression test says its good for now. the guy said he put new bearings and seals in the jet thing recently. i'm just anal about maintnance and would like to no what to watch and what to check. and what kind off 2 stroke oil? thanks :ride:
  • 97 Polaris Ultra SPX
Posted 17 May 2009 - 04:11 PM
Just use the cheap super tech oil from walmart. I assume it is oil injected right? And no they dont go through pistons and rings like dirtbikes do. Their engines are more similar to snomobile engines. Is it a twin or a tripple?
  • yellowsnow
Posted 17 May 2009 - 04:24 PM
it's a twin with oil injection
  • robr54
Posted 17 May 2009 - 04:58 PM
Everyone I know ditches the oil injection and mixes the gas themselves.
  • Zakrad_u
Posted 17 May 2009 - 05:22 PM
That what I always did with my old kawi 300sx, the oil injection worked fine, just didn't want to take any chances.
  • MotoXRyne
Posted 17 May 2009 - 06:01 PM
That motor should last a while. I have a Yamaha 650 Superjet that is 16 years old and is still on the original topend with great compression. These ski motors aren't are not nearly as high performance as our dirtbike engines and they don't rev as high either. My RM250 probably makes 45hp, my 650 Yamaha makes only 50hp stock.
  • davethegoat
Posted 17 May 2009 - 06:05 PM
As for oil , any TCW-3 two stroke oil will work. For maintainence, I always flushed the engine for a couple minutes after a day of riding. Then I would disconnect the garden hose and fogg the engine for 30 seconds or so.
  • yamaha racing 230
Posted 17 May 2009 - 06:25 PM
agreed , fog the motor if u plan on the ski sittin more than a few days, what happens is when u run the ski, the waterbox aka muffler will be full of water and the heat from the motor will be in the exhaust and then forms moister that will put surface rust on ure piston rings , i had a 98 seadoo gsxl man that ski was fun i miss it
  • yellowsnow
Posted 17 May 2009 - 06:38 PM
what do you guys mean (fog the motor)? sorry i only mess with cars and dirt bikes. my boat has a car engine in it.
  • yamaha racing 230
Posted 17 May 2009 - 06:41 PM
its called ''fogging oil '' ure local marine shop will sell it , with the motor running bring the rpm up to around 3500 aproximite and spray the fogging oil through the carbs , this will coat the engine interanlly so no rust will form
  • Fixitguy74
Posted 19 May 2009 - 05:49 PM
The 80's- early 90's Kawi's had bullet proof motors. Another vote for fogging if it's going to sit long. I used to have a pair of 1979 Wet Bikes that were a blast to ride and got a lot of looks at the lake. I miss ripping across the lake.
  • yellowsnow
Posted 19 May 2009 - 05:57 PM
takin it out tomarrow for the first time hope the water isn't to cold
  • yamaha racing 230
Posted 19 May 2009 - 07:31 PM
the water wont be the prob the outside air temp hittin ya at speed will give ya the chills , let us know how the ride goes :ride:
