yzf 426 twin ignition map
9 replies to this topic
  • gixxer7500_0
Posted May 17, 2009 - 12:39 PM
Is it a myth or is it true that the wr426 ignition has a gray wire shorted down to earth to retard the ignition slightly and the yzf426 does not have the wire shorted to earth ? if this is true could i put a swtch on the bars and have 2 map setings with the gray wire for wet or dry ?
  • TIG88
Posted May 17, 2009 - 01:08 PM
As far as I know that wire dosent even exist of the YZ cdi, but I could be wrong. The power differences have to do with cam timing, jetting, and exhaust/intake restriction too.
  • thumpyz
Posted May 17, 2009 - 01:51 PM
i dont think it is a whole different map, just a little bit higher rev before you hit the limiter. 500 rmp's or so.
  • TIG88
Posted May 17, 2009 - 01:52 PM
It is infact a different map.
Posted May 17, 2009 - 02:33 PM
It's a different map, but only on the WR. The YZ426 or 450 doesn't have it.
  • gixxer7500_0
Posted May 18, 2009 - 12:55 AM
It does exist i have found it on my bike it is in a plug off the cdi that has 2 conections one is black/white and linked to another black/white and the other is a single gray on its own if i knew how to upload pictures on here i would send you a pic
cheers
chris
  • gixxer7500_0
Posted May 18, 2009 - 12:57 AM
so if i bought a wr426 cdi it would come with 2 maps instaled and i could use either map ?
Posted May 18, 2009 - 04:37 AM
Yes, but no one I know who has ever disconnected the gray wire from a WR has ever wanted to put it back for any reason.
  • TIG88
Posted May 18, 2009 - 11:05 AM
Do you feel you have too much power, or power comes on too quickly? Is that the reason you're wondering about this?
  • FinchFan194
Posted May 18, 2009 - 12:08 PM
That would be a cool mod to have for tight single track or slimy/wet conditions.
  • Hot  36 replies
  • 0 replies
  • 9 replies
  • Hot  28 replies
