Lactating '03 WR450F
7 replies to this topic
  • Domingo
Posted May 17, 2009 - 01:52 AM
Just a little, out the drain tube. Need for concern? Couple of milky droplets on the ground after a ride. First thought was the gasket, but no smoke and doesn't overheat.
  • SXP
Posted May 17, 2009 - 06:54 AM
Don't sweat it. Condensation + oil mist = milky droplets. I imagine your humid climates make the condesation effect worse.
  • Fullbore4
Posted May 17, 2009 - 11:09 AM
Also if you went through deep water, some water may have gotten in through the crankcase breather. Just check the oil and make sure its not milky colored.
  • Domingo
Posted May 17, 2009 - 11:42 AM
Thanks Fullbore4 and SXP for your replies. I feel more optimistic now.
  • Domingo
Posted October 24, 2009 - 04:17 AM
Well, the head gasket was blown and am currently on the last leg of removing the head.
I know there has to be more than 2 head bolts. Anyone know what other bolts I have to remove?
Already did checklist:
Chain tensioner
2 head bolts by kick start side
2 10mm nuts on side of chain cover
  • Domingo
Posted October 24, 2009 - 05:22 AM
After contorting self, I figured it out that I have to remove the cams.
The search results here came up with no results on this procedure (guess this can become a reference thread on head removal)
Milky
  • tribalbc
Posted October 24, 2009 - 07:56 AM
I'd replace that cam chain too. How are the cam bearings ? They look a little beat in that shot.
I just rebuilt my 07. This tread may help a bit.
http://www.thumperta...ad.php?t=833176
Make sure you follow the manuals instructions for retorqing head and cam cap bolts.
  • ww44wrf450f
Posted October 25, 2009 - 04:05 PM
Are you gonna need to split the case and check all bearings and races -- it's a well deserving 03wr. How many miles on the bike? seeing that there's no winter driving where you live.
