My 144 has 175 hours on it and is still running strong. I try to change pistons and rings around every 50 hours. My pistons usually have a few small scratches on the skirt, usually on the exhaust side, like yours seems to have. However, I rarely see dark spots (blow by) below the top ring, and never below the bottom ring.
How often do you change your piston and rings? The KTM
manual says every 40 hours, I think.
I'm running a Woosner Piston kit now, which is less expensive then stock.
Hope this helps.
